pyoung47ExplorerAug 20, 2019Rough RideLast fall, I installed a set of Sailun tires on my Montana, upgrading to G rated tires. I’m running only 90-95 pounds in the tires. They are shaking the camper quite a bit. Last week, we cravked th...Show More
Cummins12V98Explorer IIIAug 21, 2019Weigh your tires, use the weight/inflation chart for the heaviest tire on each axle and add 5psi. Each axle may have the same psi or may not.I'm betting 80-85psi.Class Dismissed!
