19Rocke54's avatar
19Rocke54
Rubber roof
I have a 29ft. 5th wheel that I am going to b reroofing. I could use some assistance on finding 1/4" Foam Insulation Wrap that was previously on it. It sits on top of my aluminum frame, then has ply wood on top of it, then the rubber roofing. I can't find it anywhere. So if anyone had any suggestions on where to find it or has another option that works, I surely would apprecite any help I could get.
  • There is some thin fan fold foam that is used under vinyl siding. Check at any place that sells siding supplies.
    B.O.
  • You might contact a foam store. We have one locally that can get anything you need. Also a great source for new seat foam.
  • Sounds like 1/4 foam carpet pad would work. I can't see much insulation value in it more like sound deadening.
