Charlie_D_
Mar 21, 2017Explorer
RV Battery
I have a 5 year old Interstate battery that needs replacing on my 5er. I suspect that it has been failing for a while. Plugged to 120 V it showed 4 circles. Removed the 120 V power and the RV battery ...
Coach-man wrote:
?? A Marine/RV battery are starting batteries, not deep cycle batteries! They are designed for boats, and class C RV's which require starting batteries. If the battery your buying has a CCA, Cold Crank Amperage, rating it is not for you!
