Cummins12V98 wrote:
Big SNIP
His wife started filming him pulling away then had him stop. During this initial time of pulling ahead if high hitched that sucker would have dropped instantly! The video starts again and almost immediately the RV drops like a rock. Reason is when he stopped the tenion of the kingpin against the slide bar released and the slide bar released and once pulling again it drops.
CASE CLOSED!!!
And another one
No. You are incorrect here, but it is understandable.
Most people would be surprised how much force it takes to pull a trailer free of just resting on the hitch plate and not latched. That is why many times I have posted that the only way you can really know how to do a proper pull test is to do just that. Back under, barely take the weight off the legs, do not close your hitch, then pull out. I have done this. Most do not, and will not know how much pedal it takes to pull out. Only when you use the same amount of throttle can you do a proper pull test.
That is why I never do a pull test. I do a visual inspection, but do it at least three times before moving. Also, I do have a B&W, and they are much easier to do a visual than most hitches. If they are closed and pinned, and you verify the large part of the pin is completely visible under the hitch, they will not fail. Of course that is true of most hitches.
I also painted the large part of the pin on out last fiver so my DW would know what I was looking at when doing a walk around. She has instructions to do a complete walk around inspection separate from mine in case I have a brain fart. It can happen to anyone.
