bpounds wrote:
I believe that was a high-hitch issue.
Now, before we start arguing again, not all high-hitch errors are the same. Sure there is the obvious one, where the pin sits on top of the jaws, and the fifth wheel plates are nowhere near touching. There is also the situation where the plates are touching, the pin is home, but the jaws cannot close into the pin recess. It partially closes, against the bottom pin collar, but the jaw cannot fully close and the handle cannot lock. The jaw will open right up and the pin slip right past it easily.
I believe that second situation is what happened here, and the doubled up Teflon disk is the reason it happened. May easily happen again too. That particular hitch does not have a lot of handle travel to begin with, which makes it easier to not notice it isn't closed and locked, for a newbie that doesn't know his hitch well enough.
Lastly, yes they are making money off the video, but I don't believe they faked this. That guy would be the best actor ever if he could fake his wounded pride at the beginning of the second video. He was acting at the beginning of the first video, when begging her not to post it, so his acting skills are clearly not that good.
I said it from the beginning, I have seen this first hand ,where the handle would not close, call it high hitching if you must, but it was held up just high enough from a teflon disk that was warped ,and chewed up a bit , probably a 1/4" or less ,just enough the handle would not come closed all the way. Took the disc off ,the handle closed ,and he was on his way.
I agree the doubled up disk, did not help.
