JIMNLIN wrote:
agesilaus wrote:
They did not do a test pull tho it seems like they pulled the rv a short distance before it dropped.
With any brand RV hitch or any brand professional grade OTR hitch a high pin usually falls as the operator pulls forward and turning.
Saw my first OTR drop in a loading yard in the '70s. Newby driver thought a pull test wasn't necessary even after going through training class required by the loading yard and truck companies working out of the yard. He was sent down the road looking for another job.
As Ford guy mentioned the vid shows way too much gap between the plates (hitch plate and pin box plate). Looks like a usual rv slip plate and another thickness of some type.
Sad....all the name calling....... when someone makes a honest mistake.
And as usual bad mouthing the hitch .
Helped a guy in Montana couple years ago that was trying to get hitched up .The jaws just would not close all the way. He had buggered up the lube disk a bit. Had some burrs on it , and was a bit warped and was leaving just enough gap it would not let the pin box sit flat on the hitch . He had a friend there, and insisted on a bunch of stuff, wasn't lined up going in, etc, etc. I could see that isn't wasn't sitting down tight against everything, and told them, but the friend wasn't listening too much. Kept backing in ,and pulling out to the point it was getting ridiculous . I finally said humor me here, take that lube disk off ,and try it. He backed in ,the handle closed ,and he was ready to go . I said go buy you a new disc. Everyone learned something that day.
Experience helps, and hopefully you learn enough or ask enough ,that you don't make those kind of mistakes like dropping a fifth wheel. Bad mouthing the hitches ,and the operator does not help.
