We are considering doing a detached garage with an RV stall. So- my question is: what feature(s) should I include in the build? Some I've considered were: 220 power, a large sink (don't need hot water...
I put up a 30 x44 pole barn. 6 inches of concrete 4500lbs wire reinforced. 16 ft ceiling with 8ft florescent lights down the middle an 3 ft off the walls, all the light I need. Each row is on its own switch so all don't have to be on. Lots of power outlets. If you can put in a dump station 50 amp power dedicated to the rv. Good luck.
