We are considering doing a detached garage with an RV stall. So- my question is: what feature(s) should I include in the build? Some I've considered were: 220 power, a large sink (don't need hot water...
Is it going to be a framed bldg or a pole barn ? If its a pole barn all the plumbing can be done afterwards. If a conventional bldg then they will need to stub the plumbing in or put sleeves in the foundation. Either way the plumbing needs to be done before the floor is poured. You will also need heat to keep the pipes from freezing or just put a frostfree inside.
