thebudman's avatar
thebudman
RV garage
We are considering doing a detached garage with an RV stall. So- my question is: what feature(s) should I include in the build? Some I've considered were: 220 power, a large sink (don't need hot water- no need for a hot water heater), and having outlets around the garage for a centralized air compressor. What's else is on the list of things that individuals wished they had installed when their garages were built?
  • No moisture or rust problems in Reno. I would have a place to dump tanks.
  • If I didn't have a concern about security, I would extend the garage roof for a carport for my rig - and put in on a slab. A roof for shade and out of nature's elements would be my main goal.
  • Power for a welder (size depends on welder).
    MORE STORAGE. Seems like there is never enough.
    Alarm on the roll up garage door as well as side door.
    Better Ventilation for summer, insulation for winter. A/C and heat seems extravagant until it's really hot or really cold.
  • Do you mean compressed air supply connections?
    I would think about:
    Big exhaust fans
    More lighting that you think
    Wider door than you think (14 feet)
    Taller door than you need
    Outlets everywhere
    In-floor heat (but I am in Minnesota)
    Deep enough to leave the truck hooked up and the door closed
    Hot water is more useful than you think...if you can swing it.
    Inserts in the floor like 2" receivers....many uses.
    floor drain the full length
    Truck lift
    Shower/head/hot tub
    Full kitchen
    On and on and on...
  • do not sit it on the bare ground moisture will rust out every thing, under the rv.
