stpettasExplorerDec 27, 2015Rv heaterOur heater goes off. Then when we turn it off and then back on it will work and then go off
TXicemanExplorer IIDec 27, 2015Really need the heater manufacturer and model to tell much. Also, a better description other than it goes on then off. Are you on shore power or battery?Ken
Related ContentAtwood water heater problemRV Water heaterWater Heater Replacement RecommendationsReplace insulation inside heater column.Suburban SW12DEL Water Heater On/OFF switch melts???
