2007_Keystone_F
Jun 04, 2013Explorer
rv windows
Does anyone know the best windows for all round four seasons, the frameless or double pane windows? We will be full timing in the next 2-3yrs and purchusing our new cedar creek fifth wheel.
NJRVer wrote:NC Hauler wrote:joelc wrote:
I have a 2012 Cameo which is a 4 season 5er. I also researched the windows and while the double pane will add some insulation, my search and advise was not to get them because of the two following reasons:
They can crack.
RV's with the double pane might have to replace them on a 7 year cycle due to problems.
They also add weight. I have the Heir frameless windows and have had no problem with them. Should you get condensation, which is likely on the inside crack open a window or vent to relieve your unit of the excess moisture. This is what I have been told. I have not had this problem yet, and have not used it in the Winter to find out.
They added a total of 200# to my 5er.. My dual pane windows came on the 06' in my signature and I've had zero problems with them in 7 (seven), years...no cracks, no condensation, no broken seals, no "smoking up" between the two panes. I'm speaking from personal experience of having owned both single pane and two 5ers' with dual pane windows. THEY DO, seem to keep it quieter inside from outside noise, (comparing from experience, no hear say)....They also seem to keep louder noise INSIDE the 5er from coming outside, again, this noticing from my own personal experience.
Now we all know that "dual pane windows" are NOT the same as "thermal pane windows", that being said, I HAVE noticed that "MY" 5er, maybe no one else's seems to cool down a little easier when it's hot and seems to warm up a little faster when it's cold..I've camped in near 100 degree weather and in temps in single digits with this 5er and have had zero issues with the windows, and though they may offer NO insulation type help, it seems to me that they STILL offer more than single pane windows...AGAIN, speaking from experience of owning MANY TT's and 5er's with single pane windows, then the last two 5er's I owned, having dual pane windows...oh, I owned an 04 Coachmen Somerset, 37' with 3 slides that has dual pane windows and a very good friend of mine purchased this 5er when I purchased the 06'....his dual pane windows are 9 yrs old and there are no problems with his either...again, just speaking from fact's, not hearsay, but from just "MY" personal experience with both single pane and dual pane windows over the years.
I would never own another unit with single pane windows unless those single pane windows have something "special" going for them....I don't have to open windows or do anything to keep condensation off the windows, and that's over Thanksgiving when the heat is on and the wife is baking a turkey, doing all the cooking with "stuff" steaming in the kitchen....no condensate on any windows....oh..........just saying...:)
Actually dual pane windows do add insulating value. The air space between the two panes is the "insulation".
Rule of thumb: single pane R1, dual pane R2, Low E coating R3, triple pane R3, etc.
This is just laymans rule of thumb R values for windows. Not going into U values, center of pane values, edge sealing, etc.
