CarlT100
Aug 26, 2015Explorer
debraindi wrote:CarlT100 wrote:What happens if your get in a situation where you need to ride back up the ramp and your bike inst running? I get on it start it and use the clutch to hold the bike coming down the ramp. I want control at all times for what its worth .boogie_4wheel wrote:2112 wrote:
Ride it on. Have engine running when backing it out and ride the front brake. Be ready for anything.
I have mine shut off and in gear when backing out. Hand on front brake, and use it to hold about 50% of the bike; my front tire will slide on the trailer floor (but not the door). I then drag the clutch until the front tire gets on the grippy door lining and then the front holds a majority of the weight the rest of the way out.
800lb VTX1800T
I use that same technique and I ride it in to load it.
I have never had the need the need to ride it back up the ramp. The ramps are wide; I just make sure I am backing down the center, or near the center, of the ramp.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
