calewjohnson wrote:
MichaelOH59 wrote:
calewjohnson wrote:
MichaelOH59 wrote:
calewjohnson wrote:
I have them and have about 3k miles with no problems.
A buddy of mine picked up a new Cyclone 6 weeks ago, it came factory with the Sailun tires and metal valve stems.
Cale
Is it a triple axle? I'd so what size tires?
We both have 235/85R16 tires. I do run TireMinders on mine for TPMS...he runs nothing...I have had minimal increases in pressures from driving down the road.
Cale
Is your friend's cyclone a triple axle?
Yes, he has the Cyclone 4000 Elite. He has already modified the hell out of it. He has no generator, but he ordered the extra fuel tank...he runs diesel in them, installed a pump, and ran lines all the way to the front..using air tool disconnects at the hitch, and pumping fuel into the filler neck....
He removed factory toilet and uses a composting toilet instead.
He is in the process of installing a big enough solar/battery combo to run the AC unit(s).
Cale
Well now that IS interesting. I have a 2014 4018 and my clearance between tires is about 1 3/8". If I were to put on those 85R tires like your friend I wud have perhaps 3/8" clearance or less. I wonder how much clearance he has.
