JTrac wrote:
I've been thinking about changing to a heavier duty tire and I'm considering the Sailun's. My problem is I'm not sure if the wheels on my Pinnacle have the capacity for heavier duty trailer tires. It came with 255/85/r16 Goodyear Endurance. Neither Jayco or Tredit Tire and Wheel, their supplier, could tell me exactly what I have. The wheels are 8 lug and the outside width appears to be about 8 inches. Sailun says their 235/85/r16 S637 needs a rim width of 6.5 inches. Other brands give an acceptable range of rim widths but not Sailun. I would hate to order a set and find they wouldn't work with my wheels. No information is stamped on the outside of the wheels.
Tire engineer here.
Wheels: The best information I have been able to gather is that not only does the government not require a max pressure to be written on wheels, but that wheel manufacturers only consider the max load to be important. I take that to mean that stresses in wheel due to pressure are much smaller than stresses due to the load. As confirmation, I note that when people purpose try to fail a tire by inflating it, the wheel isn't what fails.
Allowable rim width range: It's size dependent, not dependent on the manufacturer (brand). That's because there are tire standardizing organizations and they are the ones who set the range - with the agreement of the tire manufacturers. If you see a spec for one brand, it will be the same if another brand doesn't state otherwise.
