Just put a set of 16" on my Montana. They pumped them to 110psi. I have 2800lbs/wheel and am wondering what psi to run them at. I know many on the forum run these tires so I am so I am asking advise f...
The load range G Sailuns have a PSI spec of 110 on the sidewalls. Unless you know the wheel-by-wheel weights of your trailer and use an inflation table from Sailun to adjust the pressures, you should run them at 110 PSI. Anything lower increases sidewall flex and temperatures - which increase the chances of failure.
