Just put a set of 16" on my Montana. They pumped them to 110psi. I have 2800lbs/wheel and am wondering what psi to run them at. I know many on the forum run these tires so I am so I am asking advise f...
I run my Sailun's at 90-95 psi with 2500 lbs. max on any axle. I tried 110 psi., but like Brewurown I just got too much bounce with that high pressure. It rides much smoother at the lower pressure.
It's possible that they recommend max pressures due to the lousy track record of the E-rated trailer tires, and don't want to run lower pressures allowing excessive sidewall flex. A little over compensation perhaps. :)
