abc40kids
Mar 20, 2015Explorer
Sailun S-637
So I want to get these E rated tires off my new Mountaineer and go with a G rated tire. I had the G-614's on my last 5er but these Sailun tires are getting some good talk... What's up with these tires...
GoPackGo wrote:Cummins12V98 wrote:abc40kids wrote:
Got my Sailun tires in today but didn't think about the valve stems. I've got the high pressure rubber ones rated at 80psi. I ordered from E-Trailer the metal ones rated at 100psi. Think there the same stems that were in my Cardinal that had G tires. These tires do look very stout.
I hope to have them on before our first trip out in our new 5er. I've got the 6 point level but I think I'm gonna use my big bottle iack to lift her up, only takes a little to get the tires off the ground.
Why would you use the "Big bottle jack" when the 6 point system is designed to lift the whole trailer? Then you can replace all 4 tires at the same time.
I have the Lippert 'Level-Up' system. I believe the manual specifically states to not use it to change tires.
FYI - When the Level-Up system has leveled the rig, the tires are most of the way, but not completely off the ground. It takes most of the trailer's weight off the tires, but I think the unloaded springs won't allow the tires to come up off the ground.
