Paul_Clancy's avatar
Paul_Clancy
Explorer II
Mar 16, 2016
Sailun versus Maxxis
Time for tires - 3 seasons from the towmax st 235 80 r16 e rated and I am down to 2 choices for replacement. The maxxis m8008 235 80 r16 e rated and Sailun s637 235 80 r16 g rated. Lt tires are off the table due to clearance can't fit 85s. My current wheels are 110psi rated sendel t06. Axels are 5200lbs.
5Th has 12000 gvwr. Hitch would carry about 2000. I know the Sailuns are overkill but I am after reliability and longevity. What would you choose? Cost is within a couple hundred so not an issue. We tow long distance in summer heat.
Thanks all.
  • I think that with ST tires, the more reserve you have the better off you are....long distances in heat, I've had good luck with Maxxis, but I would go with the "G" load range tires. (Sailun)
