pjberny5 wrote:
12600 is the total weight of the trailer loaded ready to pull
So you bought tires with WAY more capacity than required! I am just a bit under your weight with around 10K on the axles and have ran 71 pounds inflation in XPS RIBs and now R250's for years with even tread wear and lots of trips to Arizona and back. What is the weight on your axles. Around 75 lbs inflation would be a good starting point. That is 2905 per tire for 11,620 total on the axles.
BTW I added 70 and 75 inflation to the earlier numbers.
Chris
