Made picture of my filled in calculator and used you real weighed total load of 12600lbs and assumed because american 10% towbarload.
Tires I found on Sailun site as 3750 lbs maxload Loadindex 126 and speedcode L = max speed of tire 120km/75m/h.
Asumed your 5thwheeler to have 2 axles so single load maxload .
But if I am wrong correct me.
Also lowered the loadindex by 4 to 122 to give the tire a deflection that would be needed for 160km/99m/h, so saver and fulesaving and still no bumping. then it would give 105 psi as advice , and must be seen as maximum pressure with no terrible bumping, and maximum reserve for things like pressure loss in time , misreading of pressure etc etc.
Here the picture wich gives lowest pressure to have with no damage to tires and combined more load and unequall load R/L of 1260 lbs possible.
