Cummins12V98 wrote:
taken wrote:
110 PSI will not cause any of the issues noted by meagain and will give you more stability at highway speed due to more sidewall rigidity. Set it and forget it.
Maybe you should call GY Tech Support and they will tell you a completely different story.
I did call them and read what they said in their RV tire brochure. They said you should ALWAYS run the max pressure an RV tire was capable of taking unless you are trying to remedy a rough riding situation. This, according to them, would give you the best towing experience with no side effects. Glad you brought it up.
As per Goodyear's RV tire guide:
"Goodyear Tire and Rubber .... weighing RVs
Special Considerations
Unless trying to resolve poor ride quality problems with an RV trailer, it is recommended that trailer tires be inflated to the pressure indicated on the sidewall of the tire. Trailer tires experience significant lateral (side-to-side) loads due to vehicle sway from uneven roads or passing vehicles. Using the inflation pressure engraved on the sidewall will provide optimum load carrying capacity and minimize heat build-up."
As another forum poster aptly posted:
Using a minimum pressure from a tire chart isn't the best idea for a tire on a trailer for several reasons.
The biggest reason industry experts and tire manufacturers recommend max sidewall pressures is internal ply shear forces.
Tires on a multi close spaced trailer axle system in the center of a heavy box actually slide sideways at the trailer is pulled around the corner (side scrubbing).
Max pressures help hold the tires shape and helps reduce shear forces at work.
Cooler operating and a host of other reasons.
