taken wrote:
Me Again wrote:
avvidclif1 wrote:
Be very careful with your recommendations. Goodyear publishes a chart for THEIR TIRES. Ask them if it applies to other brands? I can guess the answer. If the mfg of the brand of tires you are using publishes a tire pressure vs weight chart use it. Otherwise I wouldn't be "borrowing" somebody else's. If nothing else contact the mfg of your brand of tires and ask about inflation pressures. They made them and should know.
The other problem is you have to weigh each tire to properly inflate it. Just dividing the trailer weight on the axles by 4 doesn't take into consideration the different loadings on the individual tires.
All tires except ST tires follow industry standard inflation tables. So the inflation table for a GY LT235/85R16G is the same as the one for Sailun's LT235/85R16G.
Except Goodyear specifically says do not use the load inflation chart on RV tires (including the G614) unless there is a ride quality issue.
That assumes you use the tire as it would normally be used. The OP installed tires that are greatly over rated for his trailer. The Sailun dealer said that at under 3000 lbs that full inflation is not needed. I provided an industry standard inflation table and now you are arguing about it and quoting GY not Sailun. Chris
