JIMNLIN wrote:
Now for a new guy that shows some good common sense on his part.
Jim, would you install GY or Sailun LRG tires on your trailer and run them at 110 lbs inflation? Your trailer is only marginally lighter that the OP's trailer. Mine is very close to the OP weight and there no way I would do that.
The OP trailer would have been find with LT235/85R16E steel ply tires like the Sailun running 80 pounds inflation. The LRG at 80 pounds has the exact same carrying capacity as the LRE of 3042 pounds, which is well over his actual axle weights.
Chris
