rodknocker
Dec 13, 2014Explorer
Mile High wrote:
What actuator are you using?
Using Carlisle 1600.
Update; not much to tell. Got the actuator wired up, worked first time, no issues. Ran the tubing, no issues. Started installing the rotors, big problem--either the brackets are wrong or the discs are not right. The rotor assembly goes on the spindle just fine, bearings fully engage races, etc. With the brackets installed, the rotors hit the bracket long before the hub is fully on the spindle. Called etrailer, as always, very helpful. Will know what the fix is on Monday. Oh well
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
