If you have a HDTV ready monitor don't rule out also planning on picking up full screen high def digital TV using the OTA crank up BATWING antenna.
You can watch local Natl Broadcast digital signals with this setup and will work great with the SAT TV receiver you are bringing with you.
Setup the standard way to use to OTA antenna and then use the SAT TV video outputs of the SAT RCVR to feed a VIDEO INPUT of your HDTV ready monitor.
This way you can select LOCAL ANTENNA HDTV or SAT TV by just using your HDTV ready TV Remote...
The NATL BROADCAST local TV also carries a bunch of other full HDTV signals as well.
Being in the OFF-ROAD POPUP back in the woods makes having the 24/7 local NATL BROADCAST RADAR stations a big plus for us to have to get heads up on local storms in the area.
We even do this when watching CABLE TV hookups at camp sites. Its kinda neat for us to view all of the LOCAL NATL BROADCAST TV stations in full high def mode.
Roy Ken
