anyatay1
May 31, 2014Explorer
satellite tv
We would like to have satellite tv for the camper. We are thinking of getting the portable dish and receiver,but not sure where the direct tv service comes from. I called direct tv because we are havi...
Carl n Susan wrote:
I suspect the majority of new DirecTV installs in a home utilize HD with a SWM system. Taking a receiver from home and trying to connect to the Carryout type devices is more and more a problem. The receiver only does SWM and the portable Carryout is a non-SWM, non-HD antenna.
But a SL3 dish mounted on a tripod from tv4rv.com is *VERY* easy to setup. I can have it set up, aimed (use dishpointer.com to find the required coordinates), and functioning in under 10 minutes. This way you get HD just like at home and don't have to worry about trees blocking your roof top mounted antenna.
