rhagfo wrote:
Roger10378 wrote:
I believe there are kits out there that make it so you can use low without engaging the front axle. This is what makes maneuvering with a manual much easier on the clutch.
This!
I installed a 2-low kit on my 2001 Ram 5 speed manual, made backing very easy on the clutch, could actually have it fully engaged while backing.
I installed one on my 2013 as well and it has made a huge difference. I don't believe that they are available for the 3rd generation Ram/Cummins trucks because of a different engagement system. In 2013 they went back to the axle disconnect which makes the 2 low kit possible again.
