rtreptow7
Sep 23, 2019Explorer II
Screw pulled out of exterior fiberglass wall
The pass through storage compartment on one side of my fifth wheel has a door that is held open by a latch attached to the fiberglass sidewall. One of the screws has pulled out. It is stripped. Won’t tighten back up and stay in place. It only holds the weight of the hatch open at 90 degrees. I temporarily put a little silicone around it to prevent water intrusion. But want to fix it now. Can’t get to the back side of it to fasten anything. Was thinking of filling the hole with some sort of epoxy and then re-drilling it. Any other suggestions/ideas to fix this?
https://1drv.ms/u/s!AlPYRU9A7-IqdxqpATwWZum8uKA
