noon1148's avatar
noon1148
Sealant for black tank outlet to ABS pipe
On my black tank outlet on my 5th wheel is leaking. I installed a new hose clamp but there is a sealant. I was wondering if anyone knew what sealant you put on the stub piece of pipe before you insert in the black outlet and then the hose clamp. Any help will be appreciated.
Bill
  • Your tank and piping should be ABS if they are black. Had a crack at the bottom of the outlet on mine. Sanded and put 3 layers of JB Weld and 40,000 miles and 6 years all was well.
  • ABS Repair
    I followed the advice in the links from sunlineclub.com
    Ground up some shavings from a scrap ABS coupling and mixed them with ABS cement to make a paste. Sealed a crack in my black tank where the drain pipe comes out of the tank. It basically melts/welds the ABS instead of just sticking to the surface.
  • I had grey water dripping out of my bottom (:o ) when I dumped it and after pulling part of the bottom off I found a cracked pipe going to the outlet. The previous owner had tried to fix it with some sort of glue. I wrapped Rescue Tapeon it an then for extra security I wrapped a duct tape over that. I can rest assure it will never leak again.
  • A non-hardening gasket type sealants. It would need to remain flexible
    Maybe something like this......
    I'm just surprised that any sealant was used. A proper sized rubber sleeve with hose clamps should be a leak proof fitting
    Maybe one from Grainger.....LINK
  • I made a similar repair using PVC/CPVC/ABS cement and fiberglass drywall tape. Clean the leak area and layer up the cement and fiberglass tape. It worked well on my tank and on two tanks of my son in law's trailer.
    Russ
