atwowheelguy
Feb 21, 2015Explorer
The only brochure available on the Play-Mor web site is dated 2007. The two toy haulers in the weight range you mentioned are the 8018 @ 4060 lbs. with 690 lbs hitch weight and the 8020 @ 4160 lbs. with 830 lbs. hitch weight. They are built with two 5200 lb. axles and a 9000 lb. GVWR, so they should be able to haul the 'wing. I have a Cruiser FunFinder XT-245. The "spec" weight was 4650 lbs., but it left the factory with a sticker that said 5025 lbs. Loaded with two dirt bikes (about 600 lbs. total), it tipped the scales at 6740 lbs. with a tongue weight of 780 lbs. My truck has a payload of 1607 lbs. With two people and their riding gear and tools in the truck (707 lbs. of people and stuff) and the weight distribution hitch engaged, the rear axle was 50 lbs. under the Rear Axle Weight Rating. I have since started loading more stuff in the camper and less in the truck. The tongue weights listed for the Play-Mor campers are listed as 690 lbs. and 830 lbs. with the camper empty. It gets heavy in a hurry and the payload on your truck gets eaten up in a hurry. I searched for 53 weeks to find a used toy hauler that had a bed available without unloading the bikes, would hold two bikes and wouldn't overload my truck.
About Fifth Wheel Group
