DD716TED's avatar
DD716TED
Portable Generator - EMS - seeking ideas?
Several years ago I purchased a Yahama EF2000iS generator which we used when camping in areas w/o power and water...A while back I installed a Progressive Industries HW30c EMS. I haven't used the trailer with the generator since the EMS was installed but recently I found out from Progressive Industries that the lifetime warranty on their HW EMS system is voided if used with the Yahama EF2000iS generator. Even putting the EMS remote in the bypass mode will void the warranty. Wish I had known this earlier BUT I DIDN'T.. Anyone else delt with this problem? How did you solve it! I have a camping trip to an area with no services later this summer and will require the generator. As I see it the only way to continue is either (1) remove the HW system and splice or replace the power cable from the outside connection to the power dist panel, then buy a portable EMS system or (2) just chance it and hope the HW EMS system doesn't fail hopefully not while camping. Thoughts?
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
