ford_truck_guy
May 23, 2020Nomad
FORD has a fifth wheel rating up to 22,800 on the F350 SRW depending on equipment..
that rating above is a 6.7 - 3.55 - 4x2 142" WB 8' Box - Supercab - - 22,800(4)/19,200(3,4)
BUT... there is an ** next to that... the rating is maxed at 18,000 if using the Optional Ford offered hitch, which is rated at 18k
1-18" All-Season Tires. 2-18" and 20" All-Terrain Tires. 3-Optional 10,000-lb. GVWR Package (68D). 4-Gooseneck tow rating shown. 5th-wheel tow rating limited to 5th-wheel hitch rating of 18,000 lbs. 5-17" Tires. 6-Tremor Off-Road Package (17Y). 7-Optional 11,400-lb. GVWR Package (68L).
2020 FORD TOW GUIDE
*** AND *** You can forget that high number, in reality you never get close due to the RAWR and the Tires....
Notes: • Calculated with SAE J2807® method.
• Trailer tongue (trailer king pin for 5th-wheel towing) load weight should be 10% (15% for 5th-wheel towing) of total loaded
trailer weight. Make sure vehicle payload (reduce by option weight) will accommodate trailer tongue (trailer king pin for 5th-wheel towing) load weight and weight of passengers and cargo added to towing vehicle. Addition of trailer tongue (trailer king pin for 5th-wheel towing) load weight and weight of passengers and cargo must not cause vehicle weights to exceed rear GAWR or GVWR. These ratings can be found on the vehicle Safety Compliance Certification Label.
2020 FORD TOW GUIDE
About Fifth Wheel Group
