Dayle1
Dec 05, 2014Explorer II
F14man wrote:
Seems like we fill one tank before the other is 1/3 full. Anyway to share the tow as one tank?
Depends on how much effort you are willing to make. Drop the underbelly fabric and add a 3/4" or 1" line between the two gray tanks. Could be rigid or flexible line and the high point of the line will determine at what level sharing is initiated between the two tanks. Also a level trailer will also be critical. Of course you will have to add fittings either to the tanks or the existing drain lines prior to the blade valves.
Another possible option is to use drain caps that have built-in 3/4 " hose fittings and just use a garden hose between them. Both gray valves must be open and the black valve closed. And if either of the valves is a long distance from the outlet, there will be a significant amount of gray water to deal with when disconnecting everything.
About Fifth Wheel Group
19,007 PostsLatest Activity: Feb 28, 2025
