Lantley
Mar 05, 2016Nomad
A TT can tow just as well as a 5th wheel however a 5'er will tow better right out of the box. A TT will require a weight distribution hitch to connect trailer to truck. The WDH will require adjusting and can be a bit finicky. A 5'er places the weight of the trailer in the bed of the truck which provides a better platform vs. a TT which attaches to the rear of the truck.
Because the truck carries more of the weight with a 5'er a bigger truck is usually required.
Your current truck will tow most any TT. However you will have to be more concerned with pin weight if you go with a 5'er.
There are fivers that your truck can accommodate however due to payload your selection will be more limited vs. TT's.
You may need to do a bit of homework and research towing parameters. Become familiar with payload, tongue weight, pin weight,GVW,GCWR and tow rating.
Take your time, do not trust dealers with matching truck to trailer,most just want to make a sale.
Buying the wrong trailer or truck can be an expensive mistake. Unfortunately it happens all to often. You want to get it right the first time and avoid playing the upgrade game.
About Fifth Wheel Group
