laknox wrote:
Mjmccaig wrote:
I already have a flip over B&W ball in the bed. I need that for other trailers. So I'm leaning towards putting a ball adapter on the RV. I'm not too concerned about negotiating a price, but just looking for general guidance. What are some common mistakes made buying your first 5th wheel? is one AC unit enough in hot climates? It can get close to 100 here with the heat index.
What features will I wish I had gotten that are easily overlooked being as I've never owned one? Experienced Folks, help me out here.....
First mistake, IMO, is wanting to put a GN adapter on any FW you buy. Many mfrs simply won't warranty any frame issues if one is installed. Yes, I know that many people use them without a problem, but when the downside can be so bad, why take the chance? Much better to buy a B&W Companion or an Andersen Ultimate.
Lyle
X2 ^^. The fronts of fifth wheel frames aren't built like your gooseneck trailers and the leverage applied by a gooseneck adapter will not only likely void your frame warranty on the fiver, but damage it as well. The Andersen Ultimate has a model that mounts to the truck using your existing turnover ball, as do B&W and several other manufacturers.
Rob
