Bamaman11
Jul 17, 2014Explorer
I've had a travel trailer since 1995, and have always considered moving up to a fifth wheel eventually. I had no idea so many desirable fivers weigh 14K lbs. and 3K lbs. pin weight, requiring dual rear wheels to tow safely.
I too have a F250 crewcab diesel. I am going to install a B&W Patriot 16K hitch on rails and an airbag rear suspension. My truck has an 80 hp econo flash on the computer, and I'm going to drop back to a 60 hp tow mode with a special tranny program. A TruKool tranny cooler is coming--but it's not needed on newer model SuperDuties.
That's about as good as a 3/4 ton truck gets. As much trailer I want to tackle is about 11,000 lbs. dry with a 2000 lb. pin weight--knowing it'll max my truck out after our stuff is in the trailer.
We have ordered a Grand Design 323BHS with the SuperSofa. Although the company is only 18 months old, they've already built 2,000 Reflection model fifth wheels--incredible. The Reflections max weight is where a 3/4 ton truck can pull them--11K and 2K on weight/pin lbs. for ours, the biggest model. They just came out with a rear living model that a 1/2 ton truck can handle. The BHS is a 37' 4 slider bunk house with a J couch/bed and 3 other beds in the rear room. It suits our needs perfectly.
See: http://www.granddesignrv.com/
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
