rhagfo
Jun 21, 2015Explorer III
dave14117 wrote:
Re house batteries: battery meter in the trailer indicates fully charged (not sure what that's worth, but with all the problems connecting to 115AC, I've seen it down from Good to Poor). Now at top of meter. NOTE I've tried to isolate by turning all CB's off. Result: shore breaker may trip with only one trailer CB (take your pick which one, they all will do it) on. Other four are off.
Could main breaker be faulty? I mean, tripping shore breaker by turning on a small fan connected to an outlet? This is not air or microwave or water heater. Nothing else on
Time to check wires for mouse damage. Remove all external power and disconnect batteries, and pull out the circuit breaker panel and inspect all the wiring behind, likely the feed cable is bad.
Time to consider winter camping to keep all active.
About Fifth Wheel Group
