DelCamper wrote:
What does that entail from a driving perspective? Do I have to do anything? Can I still turn as tight?
I tow with a 6.5ft F-250 and as long as im on flat ground the only way the 5th wheel would ever hit the cab is if I purposefully jackknife it, and that would happen with an 8ft bed too. For me the only time I used the slider is when I am backing in to a spot with a hump that would make the truck and trailer unlevel (\/,/\) with each other and while turning over humps to the articulation(?) of the trailer could cause it to hit the cab. With the slider pulled out into maneuvering position it gives about a foot more of play room so the trailer wont hit the cab. And the operation of the slider is simple to move from tow-maneuvering pull the slider pin out and pull the truck forward with the trailer brakes on or wheels chocked. And to move from Maneuvering-Tow pull out the slider pin and back the truck up with the trailer brakes on or wheels chocked until the slider locks in to the tow position. Happy Hunting!!!
