GaryUT
Aug 05, 2019Explorer II
RCMAN46 wrote:GaryUT wrote:
I have a short bed GMC with a patriot slider. The dealer who installed it set as far back as it would go. The pin box will hit the tailgate when the hitch is slid back:
Gary
Does your pin box clear the bed sides when you come close to a 90 degree turn?
I have plenty of clearance between the pin box and the sides of the bed, I can turn the truck to 90 degrees. When the hitch was installed the dealer set it as far back as it would go, the pivot point of the hitch was 3" behind the axle. Since the picture was taken I have adjusted the hitch to be centered over the axle, the pin box will clear the tailgate on level ground, but not by much.
Gary
About Fifth Wheel Group
