Me Again wrote:
Coach-man wrote:
Finally, what tires do you have and what are they rated for? If stock truck they may be your weak link!
It is a 2500, so tires are fine. Chris
Oh really, just because it is a 2500, means the tires are fine? What rating are on those tires, the OP or someone could have replaced them at some point. Not all ¾ ton trucks come from the factory with the same tires, Tires, and wheels have options when ordering. Tire ratings are sometimes overlooked when calculating what can be towed. And since it appears the OP's TV will be at or a little above the capacity tires could be something to be checked!
