azpete
May 21, 2015Explorer
most leveling systems are designed to be able to lift more than is necessary to raise the coach.
so, yes you can, but for liability purposes, all leveling system manufacturers state in the warranty portion of the manual that that is not to done. you should always use jack stands or some safe blocking when you remove a tire. if it falls on you, you assume all cost.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
