the_bear_II
Jun 13, 2017Explorer
You need to know a couple of things to determine if the truck will work:
Weight of the Trailer
The weight at the Pin (hitch point) of the trailer
The truck towing capacity
You should be able to find the trailer info on the manufacturers sticker affixed to your trailer. Same with the truck there will be a sticker with the info.
Use the sticker info to determine if the truck has the capacity to safely tow the trailer.
About Fifth Wheel Group
19,033 PostsLatest Activity: Mar 04, 2026
