Deb and Ed M wrote:
colliehauler wrote:
I guess I don't understand buying a unit with a slide and not using it. Even at Wallyworld you can pull to the edge of the parking lot and put the slide out.
Yeah - but then folks on RV.net criticize you for "camping" ;-)
My initial thought was keep the slides in to reduce the cubic feet needing to be heated - but we'll probably gain more heat by having the heat ducts clear, so it will be slide OUT.
I have 3 Collies so I need every bit of room I can find.:B  I have only stayed at Wallyworld a couple of times and have yet to have a manager tell me not to run the slides out, and I always ask. I keep everything in my RV other then food. I pick up food once I get to where I'm going.
