jffnkrn
May 12, 2015Explorer
Some of the new Keystone products have slides that are cable operated. If this is the case, get a ladder or look on top of the slide on the inside of the coach. There should be a flexible adapter to hook up to your drill, yep should have a drill with you and hook it up and then can do slide manually. If it is not cable operated, there should be a point to put a crank, like the ones for your jacks and turn the mechanism. But yes, get with your manufacture. Good Luck & Be Safe ! ! !
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
