Taz_23
May 13, 2015Explorer
The two smaller slides on the street side ( bedroom and kitchen slide ) are cable operated and as someone else said are moved with a flex fitting and a drill. The fitting should have come with the camper. The larger (deep slide ) is accessed under the camper. If you look at the coroplast covering under the camper, there will be a square (appox. size 14"x14") cut out held in place by 4 lag screws. The manual override is located there. A small drill with a socket will work, but I found its easier due to limited space to use a ratchet wrench.
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
