blantonmr's avatar
blantonmr
Slide out floor glue
Hey guys, my 5th wheel main slide out floor rotted due to bad trim and window leak. It was actually bad when I bought it but am trying to replace floor now. I'm going back with plywood instead of OSB but needed to know what to use to glue my floor back down. It has a 3/16" plywood bottom and 1/4" OSB top floor with 3/4" Styrofoam in between. What I scraped off looked like liquid nails but not for sure. The floor frame is aluminum so it needs to stick to it and also the Styrofoam.
Thanks so much,
Mike
  • You haven't mentioned what kind of plywood you are using. Make sure you use an exterior grade plywood but NOT treated plywood. Treated plywood contains chemicals that will corrode the aluminum frame.
  • blantonmr wrote:
    Hey guys, my 5th wheel main slide out floor rotted due to bad trim and window leak. It was actually bad when I bought it but am trying to replace floor now. I'm going back with plywood instead of OSB but needed to know what to use to glue my floor back down. It has a 3/16" plywood bottom and 1/4" plywood top floor with 3/4" Styrofoam in between. What I scraped off looked like liquid nails but not for sure. The floor frame is aluminum so it needs to stick to it and also the Styrofoam.
    Thanks so much,
    Mike
    To glue back to the aluminum frame I would use Leach's F 26, and to glue the styrofoam to the plywood and the plywood to the Styrofoam I would use Leach's F 13 as it will stick to it and not harm it.
  • [email protected] wrote:
    Look into a urethane adhesive which isn't affected by vibration, cold, or heat, or moisture it will adhere the plywood to thr aluminum nicely. Also research what adhesive will not have a reaction with styrofoam.
    Good luck!
    I did read up on chemicals that affect Styrofoam. Good points!
    Thanks
  • Memphisdoug wrote:
    I'm just curious, are you rebuilding the entire slide or were you able to get the floor structure out without dismantling the rest of the slide? From the looks of this photo you must be rebuilding the whole thing. I would really like to see photos as you progress.
    I got the slide floor out and am replacing all the floor wood and foam. Also I'm going to replace the inside wallboard as well due to one spot of leak damage under a window. I also found another soft spot on the main trailer where the power cord comes in and it rotted floor supports etc. I'm afraid that I used the wrong liquid nails on the bottom floor so may have to remove and fix that. :(
    This is all new to me but I think it will work when I'm done. I hope! :)
  • I second the additional photos. I have used an adhesive called Lexel on various projects with good results. Thanks
  • Look into a urethane adhesive which isn't affected by vibration, cold, or heat, or moisture it will adhere the plywood to thr aluminum nicely. Also research what adhesive will not have a reaction with styrofoam.
    Good luck!
  • agesilaus wrote:
    There is a 'subfloor' version of liquid nails, that is what I'd use. You can find it at a big box hardware store.
    Thank you! :)
  • I'm just curious, are you rebuilding the entire slide or were you able to get the floor structure out without dismantling the rest of the slide? From the looks of this photo you must be rebuilding the whole thing. I would really like to see photos as you progress.
  • There is a 'subfloor' version of liquid nails, that is what I'd use. You can find it at a big box hardware store.
