golf_bears wrote:
I'm going through something similar. My slide is moved in and out with a hydraulic cylinder. When I first got the loud noise when closing the slide, I found I had sheared 4 teeth off the pinion gear which drives the rack attached to the slide. Had it fixed once but they never really got it right. Loud noise continued. It happened again, slide was not closing completely on one end, stuck out 2-1/2 inches. Had another tech look at and fix. Pinion gear still intact, no teeth sheared. Made the adjustment to the pinion and rack so slide would close. Now it has done it again, slide sticks out 2-1/2 inches. So called Lippert and discussed with their tech guy. Long story short, the pinion gear is jumping out of the rack, which is why there is a loud noise. What is happening is the tube the rack slides through has bulged out and allows the rack and pinion to disengage for a few teeth. So now I have an appointment set with Lippert to fix the problem. They will fix the tube and add reinforcement so it does not bulge out again. They’ve had other customers with the same problem so they are well aware of the problem. The suggested fix makes sense to me. Perhaps you have the same problem???
same issue as yours- do you have a contact number for Lippert and maybe someone to talk to about it. thanks
