My brother-in-law had an issue with his large slide (cable-driven) that had him pulling his hair out.
Had it at the dealer to get it remedied, and they naturally just did a simple check of it and said, "It's good to go"
BIL then asked if they could go check it out and have the slide operated while he watched.
Same as yours, it would start to retract, then seemingly "bog down", and once over the hump it would continue in.
After a few cycles, BIL noticed that the weather-seal along the bottom was being pulled in when the slide retracted and the rubber was actually being forced over the rollers.....hence, the "hump" that it had to overcome.
The tech said, "Huh" and then proceeded to trim back the seal by the rollers, and voila, a smooth operating slide.
Might be worth a look in your case.
