Healeyman
Oct 13, 2018Explorer
Slide Problem
We got along for 12 years with 2 RVs without slides.
I always said, "ALL Slides ARE a problem or WILL BE a problem".
Then we figured because we are spending more time in one place, we need a slide, so... we got an RV with a slide.
It is a 2013 Coachmen Freelander 29QB.
The last time we were out, we tried to put the slide out and the front top corner wouldn't go. While the switch was pressed, I PUSHED hard on the front top corner and the slide went out fine.
Being an engineer, I suspected that I knew what the problem was. I went out and looked and I was correct.
I've got a friend with a mill, so I think that I can cut the tooth pattern in short piece of stainless and after cutting off the damaged portion of the rack, bolt the new piece to the wall.
Anybody else had this problem? If so, how did you fix it?
Tim
Tim
