ghsebldr's avatar
ghsebldr
Slide problem
After doing a short search here I thought it would save a few rabbit holes to just ask the question.
I have a 2004 Minnie Winnie 32C. Have had it a few years with no slide issues, used it last night and it came in as usual. We stopped for breakfast at a rest area and were on a pretty good slope 10 degrees maybe. When I went to extend the slide it started then immediately stopped and I got a flashing light.
After getting home I tried it on a level surface and still no go. Looked at the DigiSync Winnebago Room Slide System operation guide and it shows a slightly different style in the picture but I think it's close. The trouble shooting says that a flashing light denotes an error and mine is flashing 12 times. Which is No encoder signal detected on rear actuator.
Has anyone here dealt with this problem before that's still on this forum?
Also I've tried to open the small doors that are over the ends of the ball screw on the side of the motorhome to try to manually extend the slide. I can't even figure out how to get the little doors off of the side of the motorhome. No key, and I can't see how they open.
I would appreciate any help you are willing to share.
Thanks
1 Reply
  • After many years in electronics, I stay away from electronic controls if possible. Mechanical and electrical are much more reliable in the long run.
    That being said, I don't have any knowledge to help but thought I'd bump this back to the top see if anyone else might comment.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 28, 2026
